Jun-12-2013 11:24 AM
Jun-24-2013 09:06 PM
JLTN_James wrote:Bighorns wrote:
Everyone has given you very good advice on this issue. One more thing to add is to not let vehicles behind you intimidate you and make yourself think you are going to slow. Better to be safe than sorry. There is always enough time for everyone to get where they are going no matter what. Have fun!
Put a bumper sticker on the back that says "Don't rush me, I'm on vacation."
Jun-24-2013 05:22 PM
Jun-24-2013 12:31 PM
Jun-19-2013 09:39 PM
wintersun wrote:
I would be a lot more concerned with a gas engine but the trick is to be in a low enough gear that you can take advantage of the engine braking it does provide. Having disk brakes at all four wheels will also provide added braking ability and peace of mind.
Jun-19-2013 03:46 PM
Dakzuki wrote:So true!!! Brake fluid starts to deteriorate and absorb moisture the minute a can is open. 10 years old - you need new. One of the best out there is Valvoline® DOT 3 & 4 Brake Fluid. Has a high dry boiling point up to 480°F.liquidspaceman wrote:
Thanks everyone. I am driving a 2004 Thor Motor Coach, Class C. I believe it weighs about 11000 pounds or so.
Wouldn't be a bad idea to have your brake fluid changed. It is now 10 years old.
Jun-19-2013 03:24 PM
Jun-16-2013 11:06 PM
Jun-16-2013 10:37 PM
Wishbone51 wrote:
I have more issues going up the mountain.
Jun-16-2013 12:22 PM
mdamerell wrote:I've made the same comment about going down the hill only one time too fast but I also got that piece of advice from a fellow trucker I was in contact with on my first trip over the mountains with an over size load, Wide and 90 plus thousand pounds. Words to live by for sure. Keep those words in mind and you will do every thing you can to get over the mountain safely. Most of all common sense and attention to the road prevails
In the semi we have a couple basic rules
1- you go down a hill 1 gear lower than you went up.
2- save your brakes for an emergency, use the engine/trans to slow you down.
3- if you have to brake, use stab braking as described above.
As one ole boy told me as I creped down the Rockies for the 1st time. "You can go down a hill too slow many times, you'll only go down it too fast, once."
Take your time and enjoy the view.
Jun-15-2013 11:40 AM
Jun-14-2013 06:44 AM
Jun-13-2013 09:29 PM
Jun-13-2013 09:05 PM
Jun-13-2013 07:38 PM
