- tenbearExplorer
Dcarner wrote:
Thanks for the responses. I plan on just using the black tank flush to clean out the tank. I will close the black tank valve for 1-2 minutes and let the tank fill with water to do a secondary flush. If I find that isn't working, I will look into other options.
Seems like a good plan to me. - DinTulsaExplorerThanks for the responses. I plan on just using the black tank flush to clean out the tank. I will close the black tank valve for 1-2 minutes and let the tank fill with water to do a secondary flush. If I find that isn't working, I will look into other options.
- kennethwoosterExplorerI looked at them and then realized how I would have to find room for something else to pack up, and carry. The black tank flush works really well once you get used to working it. I would save my money.
- myredracerExplorer IISome tanks have the outlet on the bottom, some the side and some the end and they also have different configurations & dimensions. If the Flush King doesn't have a reasonably straight shot into the tank, it's not going to have much of a flushing action and will just fill the tank which you could do by filling from the toilet.
We had one of these in a previous TT and it worked great and used it every time. It doesn't help with our current TT and we use the built-in tank flusher which does a pretty good job if you let it run long enough and if there is adequate water pressure. If you have an enclosed underbelly you won't know what the tank looks like or if there is a bend in the outlet pipe. - No Fuss Flush for me. With custom spray pattern. Lots of water right where needed.
- rrevExplorer
azjeffh wrote:
rrev wrote:
I saw this the other night. It's long but it definitely shows what works and what doesn't.
https://youtu.be/dfTd0Slt_cU
Can't exactly put my finger on it, but that video looks familiar ;)
Oops, missed that. Lol one of those days I guess. - azjeffhExplorer
Can't exactly put my finger on it, but that video looks familiar ;) - rrevExplorerI saw this the other night. It's long but it definitely shows what works and what doesn't.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
