- McamperExplorerThis is pretty simple. I have never been to a gas station that did not have warnings signs posted about open flames, cell phones, containers and such. Even though the flame in the fridge is behind an outer panel and inner sheet metal panel, this flame still takes in oxygen to burn therefore is considered open to the outside.
I have seen a lot of replies that state it does not matter, or there is no issue etc... This is one reason that I stay away from any type of RV when I am at a gas station even when I am towing our RV. I agree it would not be a common happening, but accidents can and do happen.
Here is the law that is similar in most states:
"Any person who smokes or uses an open flame within 20 feet of a pump used to fuel motor vehicles or a fueling tanker being used to deliver gasoline to a gasoline station is guilty of a Class 3 misdemeanor if smoking or the use of an open flame is prohibited by a sign at the pump. Any person who causes a fire or explosion as a result of a violation of this section is guilty of a Class 1 misdemeanor." - JaxDadExplorer III
wa8yxm wrote:
When I took the AEON insurance Safe Driving course the insurance company naturally said "TURN OFF PROPANE AT THE TANK".. I do understand why.
I’ve learned to take what insurance companies have to say with a LOT more than a grain of salt.
A couple of years back my home insurance company came out to do an ‘assessment’ because my coverage was so different from a standard policy.
When we got to my aircraft hangar and fuel tank the ‘expert’ was satisfied with the tank, but was really shocked to find out the plane inside the hangar was full of AvGas!!!
He was so adamant this was totally unsafe he called the local FD’s fire prevention officer who was onsite in minutes flat. The fire cop was also freaking out.
When I asked them both if they drained the gas out of their cars before they put them in their garages each night they got a little calmer. - DrewEExplorer IIOne of the main reasons for propane off or not permitted in some tunnels is that propane is heavier than air, and if the tunnel is U shaped, lower in the middle than at the portals (as when going under a city or body of water, for instance), propane that leaks out or otherwise escapes tends to collect in the tunnel and stay there. Tunnels through mountains, which are usually constructed to be higher in the middle than at the portals, often don't have the same restrictions since propane naturally tends to flow out of the tunnel. The main reason for constructing the tunnel with the portals lower than the middle if that is possible, of course, is so that water won't collect in it.
- campiglooExplorerThings burn. Whenever you have millions of anything a few of them will burn. I travel with mine on, even when fueling.
I always thought the reason in tunnels and on ferries is your trapped; so just for extra precaution turn the valve off. Would they let you go through the tunnel with your generator running with a few gallons reserve in your (or my) cheap plastic gerri can, er small bomb? Maybe but I hope not. - austinjennaExplorerI travel with it on and dont turn it off at gas stations either
- sgfryeExplorertravel with it on....
- dave54Nomad
hotjag1 wrote:
I totally agree with you ScottG. I think quite a few people don't know that the tanks will shut the flow of propane off if the lines are ruptured.
Supposed to.
In a violent crash they do not always shut off. Or were defective. Personal experience. Seen it twice in a 32 year career in fire.
How many RVs passed through my area in a 32 year career? Hundreds of thousands? Millions? I cannot even WAG. So a line rupture and fire is quite rare, but possible.
The risk is extremely low, but not zero. Having said that, I usually travel with mine on. I also occasionally practice an emergency total shutdown of my rig including battery disconnect and tank shutoff -- just to see how fast I can do it. - Cocky_CamperExplorer IIWe run it. We just stop and turn it off before going near fuel pumps and leave before turning it back on.
- hotjag1Explorer II
ScottG wrote:
old guy wrote:
I am the RV doctor and the guy from tv education 101 say leave it off. I was on the fire dept for 30 years and fought several rv fires that started in the back of the fridge because they thought it would never happen to them. come to my town and see the new rebuilt gas station we have because of a motor home fridge was left on and he gassed up and burned the place down and a ups truck refueling next to him. there are some tunnels back east that tell you to turn off your propane when going through the tunnel. must be a good reason for that, right?? In my mind there are a lot of people who think it's ok because they have gotten away with it for years. their turn is coming. Murphy will see to that. I use freezable ice packs to put int he fridge between the food when I travel and at night when sleeping I refreeze the packs for the next travel day
I rarely ever post here anymore because of all the jackarses but this kind of stuff needs to be responded to.
First, in an accident when the PP lines are ruptured, the tanks will shut the flow OFF.
Second, I have TWO career fireman living in my neighbor hood. One is a retired Captain and the other is currently a Commander. I talked to both of them in depth about this subject and in their combinded 60+ years of experience, they had NEVER seen an RV fire caused by a fridge. Many eng fires that burned rigs to the ground but NO FRIDGES.
Third, RV fridge fires were caused by manufacturing defect MORE THAN TEN YEARS AGO. Unless you have one of those fridges and have refused to get the FREE safety recall done, your chances of having a fridge fire are astronomical.
Finally, tunnels, ferrys, etc want people to turn of the propane period. This has nothing to do with RV fridges at all.
Now you can flame me all you want, I have no respect for you because of the outdated and made-up nonsense you spread but folks need to know the truth.
I totally agree with you ScottG. I think quite a few people don't know that the tanks will shut the flow of propane off if the lines are ruptured. - path1Explorer
Grit dog wrote:
path1 wrote:
Very seldom anymore. $25.00 wireless temperature gauge tossed on dash. I can keep eye on temps. I can go all day driving in most weather without it running. Guess depends on fridg/freezer.
Why? To save the $0.25 of propane or just like watching fridge temps?
So far we've got 1 no, 1 I'm not sure what, contradicted himself. 1 rarely. Who cares picks side of the fence and the rest yes.
For the no, maybe and confused, please
tell the rest of the class what makes it more dangerous than running when stationary? Or do you just believe propane is out to get you?
Actually the truth is my wife can see the temps for herself. Seems whenever we would stop, as soon as we get going again she would ask if I checked what the temps were, because she forgot to look Got tired of it.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
