rhartman911's avatar
rhartman911
GETTING POWER TO TRAILER
Hello my wife and I will be staying in are 26' 5th wheel until we get are manufactured house put in aorox 4 Mo. The closet I can get to the power is 40' so my question is what setup should I go with its winter time so I don't think will be using the air con will probably use a small oil type heater that plugs in to heat the place to cut down on the propane cost
1.) I was thinking of using a 10/2 extension cord type wire its weather and chemical resistant/30amp 110 breaker
2.) Or should I run 10/2 outside/direct buried wire /30amp 110 breaker
Both ways will cost about the same and it will only be temporary any advise would be helpful
