- loneryderExplorer
4x4van wrote:
Tons of LED info on this site. "Search" is your friend. Here's my thread on the subject. I, too, had the 1141 bulbs (BA15s base).
Great info. Thanks. - 4x4vanExplorer IIITons of LED info on this site. "Search" is your friend. Here's my thread on the subject. I, too, had the 1141 bulbs (BA15s base).
- wa8yxmExplorer IIIOne word of caution on E-Bay LED's... I have purchased several LED lamps. most were at least as good as a 1141 (A slightly less powerful replacement for a 1156) and I call those good.. Some were... Well I do not like using that kind of language.. Very dim, Very blue and Very short lived is the polite language.
Thus my advice
Buy one, not where, if you like it buy a dozen. (more or less) - tenbearExplorerjamway is correct. The ones gbopp linked to are a smaller bayonette base (BA9S) than the 1141 bulbs. The 1141 have a BA15S base.
I used the same panels that jamway linked to and found them to be very similar to the 1141 bulbs in brightness and color. I also used some 18-5050 cob style bulbs, similar to the ones handye9 linked to but with 18 leds. The 24-5050 may be a little brighter.
In any case I would advise you to buy a couple and try them before buying more. I have found a wide variation between sellers on eBay. - loneryderExplorerThanks all. This is great. I thought I may need some electronic converters or something. It looks like just plug and go.
- jamwayExplorer
gbopp wrote:
Flat LED's Ebay
Be careful I don't think that will fit a 1141 socket. This one will 1141 adaptor - gboppExplorer
- ChooChooMan74ExplorerI just saw this site http://www.m4products.com and thought these people had some good stuff.
- camper19709ExplorerI had good results buying the LED replacements that have a base with wires that connect to a flat square that has the led lights on it. The flat square has a sticky backing that sticks to the inside of the light fixture. I wish I could find the invoice. I think it was from Amazon. They were very inexpensive ( about $1.99 each) and of course were from China.
Hope that helps. - jcsbExplorerdo your research. There are flat panel ones also, for ceiling lights.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
