RobtWms's avatar
RobtWms
Grey water gravity drain through a FloJet?
I'm going to use a FloJet to discharge black water into a sewer inlet that is about 3" higher than my RV discharge tube.
May I run a hose down hill and leave the grey water tank valve open to gravity drain grey water with the FloJet in place or must I remove the FloJet?
Thanks in advance!
  • if your flo jet has a grey water bypass, you can easily drain your grey tank by gravity, if not,no. which is why I would always buy one with the bypass feature.
    bumpy
  • If you are not at home, be aware that very few places is it legal to just dump gray water like that without it going into the dump station.
