RobtWmsExplorerOct 09, 2013Grey water gravity drain through a FloJet?I'm going to use a FloJet to discharge black water into a sewer inlet that is about 3" higher than my RV discharge tube. May I run a hose down hill and leave the grey water tank valve open to grav...Show More
Old-BiscuitExplorer IIIOct 10, 2013If you are using it to pump black then use it to pump grey........
Related ContentGravity fill portFlojet portable maceratorCenter of Gravity Truck CamperGravity Water FillFloJet macerator
