JoyNoelle's avatar
JoyNoelle
Help me understand my 6 volt batteries
I am still a little green with the RV world. I needed to replace my batteries on a 1983 travel trailer. I had room and decided to go with a set of 210 amp hour 6 volt batteries from Costco. They are set up in a series (Thanks Dad!).
I will be visiting both Yosemite and the Grand Canyon this year and will have 3 nights at each location where I will have no hookups.
I do have a 1600 W Generator (WEN 56200i) from Amazon.
My plan is to use my generator to recharge my batteries and run mainly off battery power. I don't have a microwave or coffee maker so no need for the 120 volts that I can foresee.
I am trying to figure out at what voltage on my multi meter should I start recharging my batteries off of my generator and when should I stop using the generator to charge my batteries.
I have an old school converter (not a 3 stage) so I know I am going to be doing some damage to the batteries but I want to not discharge too far or overcharge if possible.
Also, I am hoping to run the propane furnace with furnace fan at night. Do you foresee that being a problem with running my 210 amp hour batteries down too far?
I don't think I will need Air Conditioning but if so, I only have a small Window Unit that is 360 Watts so I should have enough juice to run off the Generator.
Thanks for your input and I appreciate you helping me with my learning curve.
