- PatJExplorer IIHave a pair of EU2000 since 2005 with a bazillion hours and oil changes once annually each fall.
I put the gens on 2x4 blocks on edge (which I have laying around) and tilt to drain into a dollar-store cat litterbox (basically a roughly 9x12x3" plastic container.) The EU2000 already has the little trough to direct the drainage. No extra parts purchased.
I use a tiny (cheap) funnel to refill, I think it was from WalMart or similar. I tilt it to the non-fill side and grossly overfill, then tilt level and drain the excess in to the litterbox via the built-in trough. There is very little waste overall but it works well for me. I am over 1k hours for both EU2000 gens and they run like new. You're overthinking it. - Grit_dogNavigator
CharlesinGA wrote:
For the money this is a bargain, machined, anodized aluminum, drain tube and magnetic dipstick.
https://www.amazon.com/MOEBULB-Magnetic-Dipstick-Compatible-Generator/dp/B08FJ7QJP2/ref=psdc_15708811_t3_B087CVQNC6
Charles
Cool!
I’m gettin one of them.
The little drain spout thing looks handy too goducks10 wrote:
Go solar. I haven't used my Honda 2000W gen since adding 400w of solar. YMMV
Curious if you know what's the ROI on a Solar setup.- BipeflierExplorerCheap turkey baster.
- goducks10ExplorerGo solar. I haven't used my Honda 2000W gen since adding 400w of solar. YMMV
- CharlesinGAExplorerFor the money this is a bargain, machined, anodized aluminum, drain tube and magnetic dipstick.
Charles - JimK-NYExplorer IISo it appears the best technique would be to use a screw in plastic tube when emptying and to slowly fill with a syringe. Or you could just grab a couple of paper towels.
- BobboExplorer II
theoldwizard1 wrote:
more expensive, but more useful for other things Form-a-funnel
Years ago I bought a 3 pack of flexible cutting boards. I am still using them to make ad-hoc funnels or protective shields. Dirt cheap. They cut quite easily with ordinary scissors. - theoldwizard1Explorer IImore expensive, but more useful for other things Form-a-funnel
- IDmanExplorerShould have bought a Yamaha.
About RV Newbies
4,028 PostsLatest Activity: Mar 08, 2025
