Well depending on where you "Tank up" several months is ok. CITY Water (if you have city water at home) is often chlorinated. also there is a formula for adding bleach to well water to help it last longer. Or Fresh Water tablets from RV store. (Formula on bottle on the tab's. I DO NOT KNOW IT for either one.
My story
Due to over chlorination in the place I winter camp (Even filtered 2x I can taste it) I took a hint from my Fish Tank days.. (Fill a bucket and let it set a while) I fill my 80 gallon tank and use it. The water only needs sit for a few minutes for the blech level to drop to the point where I can't taste it.
And here in MI I have a "Questionable" and a "Good and tested daily" park (Where I am now) so I take on water here and use tanked at the other park
Longest I've gone doing it this way
Tanked up the day BEFORE halloween last year. Drove to Tekonsha. then drove the towe dup to Marshall (Michigan towns) to get a new converter 238 dollars back to Tekonsha to install it and on to South Carolina.. Where on Thanksgiving morning I ran out of water.
Tanked up for the first time in 4 years off the Pioneer Water District Water and went through 80 gallons in a week (Well. that happens when you change water
๐
