- Matt_ColieExplorer IIAs I recall (this was a lot of years ago) a bumper or 5er will be measured from the center of the hitch to the center of the load wheels. So on a tandem axle, that would be the center of the tandem set. A triple would be measured to the center of the set also, there just may happen to be a spindle there.
Matt - Some are measured from the center of the ball to the front axle center line.
- bren5666ExplorerThe overall length is 26'7". I'm wondering if they're not measuring from the tongue to the rear axle. I haven't picked the trailer up yet or I'd just measure myself.
- downtheroadExplorerIt's all over the place...brochure lengths could be either...
- length of the box only
- length including the hitch and rear bumper
- or??
- frankdampExplorerThe true definition of "wheelbase" is the distance between the center-lines of the front and rear axles. I've never seen a TT with axles 17 feet apart. Maybe the literature you're reading the data from is using the wrong word to describe some other dimension.
- popupcampingExplorerMy guess would be from Ball to centerline of wheels or center of axles.
I would get a measuring tape out and just measure what is 204" personally.
kind of an unnecessary number IMO
About RV Newbies
4,030 PostsLatest Activity: Jul 30, 2024
