โApr-27-2014 04:31 PM
โApr-28-2014 10:34 AM
โApr-28-2014 10:19 AM
โApr-28-2014 09:54 AM
doxiemom11 wrote:
Regarding the use of water. If TP or solids are being flushed, water should be included to insure that when you go to drain the tank there is enough water to flush "paper and stuff" out. If you run out of liquid, you are leaving stuff behind which will eventually cause problems. #1 with TP - finish filling bowl with water and flush - #2 with solid and TP, finish filling bowl, flush - fill again and flush. 3 years of full-time using that method and we have not had any problems with odor or clogs. We do not use any chemicals nor do many full-timers as we have found out they are unnecessary if you use enough water. So I would go along with hubby's method of flushing.
โApr-28-2014 09:31 AM
โApr-28-2014 07:39 AM
โApr-28-2014 03:04 AM
โApr-28-2014 02:45 AM
โApr-27-2014 08:40 PM
โApr-27-2014 08:13 PM
โApr-27-2014 07:12 PM
โApr-27-2014 06:15 PM
โApr-27-2014 06:05 PM
CarpFishermanAndWife wrote:
Oh ... forgot to also ask - at nearly every empty CG site we saw, there was some kind of residue (powder?) around where the TT or motorhome tires sit. We assume it was some kind of ant deterrent/killer. Being new to camping, we just brought a can of Raid. What is the powder substance? Thanks!
โApr-27-2014 05:55 PM
โApr-27-2014 05:16 PM
โApr-27-2014 05:09 PM
