Chaz59's avatar
Chaz59
lift capacity for elec. rv jack
Does a 3500 lb elec. rv jack,lift 3500 lbs or is this referring to the weight of the rv , not the weight on tongue.
thanks
  • The 3500 lb is the "Max load". Meaning, that's how much weight the jack can lift.
    When selecting an electric jack, you need to consider the total weight it will be lifting. It not only has to lift the trailer tongue, but it also has to lift the attached tow vehicle. The higher the lift, the heavier the tow vehicle becomes as it's lifting weight off the rear springs.
  • Powered tongue jack specs refers to the max weight it can lift and not the weight of the RV it is intended to be used on.
