New to forum, but not RVing. Have owned popup, hybrids, travel trailers, and pickup campers. Have been without an RV for 8 years, but been delivering new Class C rental units from the factory to various rental locations for 8 years to get our RV fix. Decided to buy a class C so we could do short trips, pull a trailer with a motorcycle in it, and go when delivery season was over. So I found a 2001 Four Winds 28 foot Class C on a 2000 Chev Express G 3500 chassis. A legit 41K miles and in good shape with new tires. Super dusty inside and faded on the outside, but everything worked except for the furnace blower motor. Rides nicer and is quieter than the new Fords we have been delivering.
I'm mechanical to some extent and do all the simple maintainence on my vehicles, oil changes, other fluids, sparkplugs, brakes, etc.
However after the first time out a fuel line has started to leak and it appears to be coming from where the lines disappear under the tank cover and head to the in tank fuel pump. The tank butts up against a frame cross member so I think it needs to be dropped to see what is going on. Only leaks when pressurized. At any rate something I'd not like to do on a crush asphalt driveway or really at all.
Called dozens of auto shops and no one will do a Class C because they can't fit it in or lift it. Many shops referred me to a large GMC light, medium and heavy duty dealership that does service RVs. Unforturnately they won't work on RVs older than 15 years. All local RV dealers I called will only work on the house side. Finally found two shops about 45 minutes away in opposite directions that will work on Class Cs. Unfortunately the first appointments are June 16th, and July 11th. Doesn't do me much good for a trip next week. I'm in the Denver, Colorado metro area.
My questions is: Is my experience common? What happens if I break down several states away and I can't do the repairs?
I bought it at a good price and once this gas line issue if fixed it will be good to go. If serving is this hard to find then I just want to admit to myself I made a mistake and sell it this summer before something else breaks.
I'd consider a TT again except I wanted to pull a trailer for my motorcycle and can't do that with a TT unless I get a toyhauler, but then I need something bigger to haul that and with the lack of new trucks/SUVs and run up in used prices it is crazy to buy something now. So back to flying places or taking the motorcycle all the way. Still can get in a rental delivery or two though.
