- DrewEExplorer III
CharlesinGA wrote:
db ratings are not linear. The open frame unit you reference is rated at 64 db which is a LOT louder than one that is say, 56 db which is more in the realm of enclosed RV type inverter units.
Decibels are not linear in terms of power (and energy), but they are pretty near linear with respect to perceived loudness. We don't perceive acoustic power in a linear manner, which is partly why decibels are useful units. An increase of 8 dB is definitely noticeable but not what most people would characterize as a LOT louder. - CharlesinGAExplorer
ronharmless wrote:
pianotuna wrote:
I would disagree with that assessment; an inverter does make the inverter generator quieter than a conventional generator (how much quieter can vary significantly depending on load). I'm happy with my generator, for my use it has been a great value, and no one else has ever complained about it.ronharmless wrote:
CharlesinGA wrote:
"Champion 4000-Watt RV Ready DH Series Open Frame Inverter with Quiet Technology"bid_time wrote:
In my opinion, the best buy for the buck Clicky
YOMV
Great way to Pi$$ off anyone within a quarter mile of you, and you will grow tired of hearing it too. No open frame generators for RV'ers, be a good neighbor, get an inverter unit.
Charles
You must of been having a bad day and skipped right over that word "inverter"
The "inverter" doesn't make the unit quieter. You must have skipped over "open frame".
Now, to be perfectly clear, an enclosure would make my generator even quieter, no dispute from me. But for $20 I could build an enclosure with sound insulation, that could still provide the necessary air flow. But I don't need the enclosure, others may need an enclosure. If they do, they may want to go ahead and throw in the extra cash and go all-in for an enclosed inverter generator. What ever floats their boat, I'm good with what i have.
60db is the National Park Service limit, that is why all the enclosed RV type generators strive to get under the magic 60db. Yours may not be as loud as a real cheapie non inverter, constant 3600 rpm unit, but it is, at 64 db, more than I would want to listen to.
Charles - TvovExplorer IIWell, this is one odd thread! Started by a spammer, and added on to.
- macjomExplorerI've been very happy with our Champion generator. It is quiet and very reliable.
- JonWalterExplorerWe love our quiet and fuel efficient Honda generator! We also usually take our old, heavy backup along with us too, just in case we should need it for something since we have small children - which was nothing special from Harbor Freight.
https://printsbery.com/planner-templates/calendar - pianotunaNomad III
ramyankee wrote:
Probably would not power two ACs, correct?
For two roof air conditioners Yamaha makes a 4500 watt inverter/generator.
I believe Honda makes a 5500 watt unit. It is apparently equipped with blue tooth.
https://www.electricgeneratorsdirect.com/Honda-EU7000IS-Portable-Generator/p14017.html
Champion makes a dual fuel 4500 starting watt enclosed unit:
https://generatorbible.com/generators/champion/_200991/ - ramyankeeExplorer
enblethen wrote:
Not sure if you have Harbor Freight north of the border. This would be my genset of choice. 3500 watt genset
I have two Honda 2000s and parallel kit , Not that thrilled with them.
Probably would not power two ACs, correct? - TeamjdExplorer
#1Flyboy wrote:
.... IF you buy a Honda you will pay more, but you will get more. Service, reliability, resale value and a proven generator. If you get a Communist China knockoff you will pay less but also get less and it might , maybe, produce the stated power output....
You do realize that Honda generators are made in Japan, China, Thailand, India, and US. While they are reliable and probably easier to get them fixed, it's pot luck where it was made. - pianotunaNomad IIIAE5TE,
I had a cage made, after my Yamaha 3000 developed wings. - AE5TEExplorer
pianotuna wrote:
JalynRohan wrote:
I already have a Champion 3400 ***Link Removed***. Does it sufficient while traveling?
Yes. But if you wish to run it while traveling I'd suggest a cage or at minimum a rack with a hardened steel cable.
I have this unit. It is a good value but the feature that makes it easy to handle also makes it easy to steal. I do use a heavy locking cable. If anyone knows of a suitable ready built cage I would love to hear about it.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
