Audioa_fan's avatar
Audioa_fan
Overheating Brakes
We just took our first trip in our new 2001 HR Ambassador. Things were already off to a bad start due to a flat rear tire that I posted about separately. We made it fine up to near our exit. 5 Miles from the I-40 Pigeon Forge Tennessee exit the interstate shutdown. We moved a few hundred feet over the next hour or more. Inching forward like that didn't seem to me to be a problem with the brakes. But then the problem was cleared up and I made it to my exit and hit the always terrible traffic going toward Pigeon Forge. I think I hit every red light. Then I started smelling something. I thought it was the heat at first. But I turned it off and it continued. Then I found out that it pulled hard to the left every time I hit the brakes.
When we got to the RV park I walked around and felt of all the wheel hubs. They were all ice cold except for the right front that was pretty hot. I was very concerned about permanent damage to that brake. But when we departed 4 days later the brakes worked perfectly.
Another lesson learned. An enormous amount of kinetic energy is dissipated as heat when you try to bring 26,000 pounds from 45 MPH to 0 MPH, over and over. I thought I was planning ahead and being gentle on the brakes, but clearly I need to do a far better job of that. I also do not understand why only the front right wheel overheated.
