Rusty ball
thehippie
I Bought this ball hitch less than three months ago and it’s only sparingly used. But I wonder why this got Rusty here pretty quick. It’s even rated 30,000 pounds
Anyone experience this?
Is it still safe to use?
https://ibb.co/6ghfqwW
29 REPLIES 29
SidecarFlip
enblethen wrote:
Heat treated raw steel.
From website
"Fits 2-5/16" couplers and accepts up to 30,000 lbs. GTW
Constructed from high-strength raw steel
Heat-treated for optimum wear resistance
Zinc-plated hex nut and helical lock washer for secure mounting
Features fine threads for superior holding strength
Tested for safety to meet U.S. VESC V-19 specifications"
Heat treated is not hardened. Heat treated is stress relieved so it don't fracture under stress.
If the ball was hardened (and that would only be case hardened not through hardened), it would stress crack. Hardened steel is also brittle. The ball is normalized, not hardened.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
afidel
I use Vaseline instead of grease, provides the same lubrication and anti-corrosion protection but if it gets on the clothes it's no big deal.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
enblethen
From website
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SidecarFlip
Grit dog wrote:
enblethen wrote:
Hardened steel may get some light surface rust, but will not pit as shown in photo. Curt website does not show any chrome plated 30,000 pound 2 5/16 balls.
Noticed the same.
Sure you don't mean forged, not hardened?
SidecarFlip
allen8106 wrote:
Don't sweat it. It's not worth worrying about and don't add grease to the ball, you'll regret it the first time you rub up against it with your nice jeans.
That seems counter productive to me. The coupler has to move on the ball when the trailer is turning so a dry ball imparts undue friction. Keep your balls greased, they slide easier.
I don't make it a habit of rubbing my pant leg against my balls so greasy pants legs not an issue and I wear gloves when handling the ball hitch too.
SidecarFlip
GDS-3950BH wrote:
cavie wrote:
Curt. Enough said. Chinese junk. Advanced auto Parts replaced Reese with Curt. What does that tell you.
And just when you thought Curt was Chinese junk, THIS seals the deal.
Making the slide for sure. if it's LCI, you know it's gonna be bad.
Bobbo
I always tow with grease on the tow ball and the WD pivot points. I am careful when I get around the grease, and don't wear good clothes while working the trailer.
Bobbo and Lin
allen8106
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
philh
as said above, hardened steel will get a light coating, not pit.
Grit_dog
Nomad III
Nomad III
Noticed the same.
enblethen
Bud
USAF Retired
Pace Arrow
drsteve
Everything LCI touches turns to garbage...
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
TenOC
enblethen wrote:
Only 30,000 Curt balls are not chrome plated but hardened raw steel.
Curt 30,000 balls
A hardened RAW STEEL will rust very quickly (less than a day) unless covered in grease. I think they sell a chrome plated version for more $.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
GDS-3950BH
