NorCal_Dan
Jul 27, 2014Explorer
We Cant Wait wrote:
Some units have both a Cable and Satellite coax connector on the outside of their units, look to make sure there isn't a Satellite coax connector in a different location.
X2. Also make sure the amplifier for the crank up antenna is shut off. Nothing wrong with running the coax direct to the receiver, but it makes a cleaner install if you can use the normal input on your rig. Any modifications you make to the pre-installed cabling in your rig will most likely affect your setup when hooked up to CableTV or try to use your crank up antenna for over-the-air signals. It's a pain if you have to reconfigure the rig everytime you change your TV connection.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
