โFeb-19-2016 11:44 AM
โFeb-19-2016 01:07 PM
โFeb-19-2016 12:53 PM
sch911 wrote:If it's a fuel issue I'd be looking at that too. Doesn't that happen when things get too hot?
It really sounds like a fuel issue to me. Vapor lock. Restarts after it cools down a bit.
โFeb-19-2016 12:52 PM
โFeb-19-2016 12:45 PM
โFeb-19-2016 12:39 PM
Fla904 wrote:If I could say more I would.. my opinion is this will have to be diagnosed in a shop.2oldman wrote:That doesn't say much, ..
You have an electrical problem.
โFeb-19-2016 12:35 PM
Mont G&J wrote:
He said it runs fine at high speeds, but shuts-off when he slows down. Don't sound electrical to me, more like fuel starvation.
โFeb-19-2016 12:31 PM
โFeb-19-2016 12:27 PM
gbopp wrote:
Did you check all your battery connections for corrosion and make sure they are clean and tight?
Also check for a loose ground wire. I've noticed over the years that bad connections can cause a lot of weird problems.
Always check the cheap easy things first.
โFeb-19-2016 12:19 PM
โFeb-19-2016 12:16 PM
โFeb-19-2016 12:12 PM
โFeb-19-2016 12:11 PM
โFeb-19-2016 12:09 PM
โFeb-19-2016 11:53 AM
โFeb-19-2016 11:52 AM
