Fla904
Feb 19, 2016Explorer
gbopp wrote:
Did you check all your battery connections for corrosion and make sure they are clean and tight?
Also check for a loose ground wire. I've noticed over the years that bad connections can cause a lot of weird problems.
Always check the cheap easy things first.
Last time I checked all the battery connections were fine. I just had it serviced two days ago and the mechanic said everything looked great. This is a real bummer I can't afford any major issues. Not to mention the generator issues which I've been having. I really just want to make it home and I'll take it to my local mechanic but breaking down in North Carolina will be to expensive for me right now. If it's a fuel issue is that normally a expensive fix? Does it sound like I can make it back or do u think ill break down again? Now the ac is working again.. Go figure. No idea what's going on.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
