Tyler0215
Feb 19, 2016Explorer
I think you need to get to a shop soon. The problem won't get any better the more you drive. When it shuts down do the dash lights, radio etc. also go
of? If you can try to restart as soon as it shuts down you don't have a ground or loose cable. I had a similar problem with a dual fuel tank system. The truck would run fine on the one tank at high speed but would die at idle. Needed a new fuel pump in that tank. Your AC is a completely different problem'
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
