โMay-23-2014 04:21 PM
โMay-25-2014 09:07 PM
Burwoods wrote:But again, you have a transfer box for your part-time 4WD so none of this applies - according to that manual you CAN tow it 4-down.kaydeejay wrote:Got it thank you, makes sense to me now. Sometimes I just need to be taken by the hand and walked through it..lol. Thanks again.
Hi Sally,
No way you want the steering unlocked if you tow with the vehicle backwards, the rear wheels raised and the fronts on the ground.
Running in reverse would immediately result in the front wheels turning full lock one way or the other due to caster effect. They MUST be locked in the straight ahead position so the vehicle simply acts like a trailer.
โMay-24-2014 07:25 PM
kaydeejay wrote:Burwoods wrote:Hi Sally,
Same manual I was looking at, this may sound like a stupid question, but wouldn't you want your steering wheel in an unlocked position if you were towing with the back wheels up so that they turn and do not damage your steering? Sally
โMay-24-2014 06:47 PM
โMay-24-2014 04:32 PM
kaydeejay wrote:Burwoods wrote:Try this one. from GM of Canada that says a 4WD IS towable 4-down. Section 4-44 spells it out.opnspaces wrote:This is where we found 2000 Chevy Tracker Manual
Can you post a link to the manual?
http://justgivemethedamnmanual.com/chevrolet/chevrolet-tracker-owners-manual/
A 2WD (ie NO transfer case) has to be towed with the rear wheels off the ground.
You say you have a second shifter to select 4WD?
Even if you run in 2WD most of the time, you have a transfer case and you can tow it (according to the above link).
Ignore the bit about clamping the steering wheel, that is in the wrong place and only applies if you are towing backwards with the rear wheels off the ground.
In fact those pages are VERY badly written and actually contradict themselves as a couple of paragraphs later (section 4-45) they tell you to move the key to the accessory position to unlock the steering wheel!
โMay-24-2014 03:11 PM
โMay-24-2014 02:07 PM
โMay-24-2014 01:06 PM
โMay-24-2014 01:04 PM
opnspaces wrote:
Does your tracker have a second shift liver to put it in 4 wheel drive?
โMay-24-2014 01:01 PM
โMay-24-2014 01:00 PM
โMay-24-2014 12:56 PM
โMay-24-2014 12:45 PM
โMay-24-2014 05:53 AM
โMay-24-2014 04:22 AM
Nutinelse2do wrote:Burwoods wrote:loulou57 wrote:
Please correct me if I am wrong here..... Just asking!
I was always under the impression that you never towed a 4WD you put them on a trailer. If I was ever to need a tow with my 4WD, my hubby said make sure they flat bed the vehicle.
ok so hubby says it is a standard two wheel rear wheel drive you can put into 4 Wheel drive. I have no idea what I am talking about obviously, but seems I am the one asking. After reading the internet for hours I thought no biggy but transfer case in Neutral, and gear shift in neutral, make sure key is in ignition to unlock steering and attach two bar and off you go with 4 down. Now I find something on line that say you CANNOT tow as a dingy at all. So confused.
Is it a 4wd or 2wd?
We towed our tracker 4wd for many thousands of miles. The question is which is it? That will answer your question.
If it is 4wd, put the 4wd transfer case in neutral and the key to first position to unlock the wheel. Easy peasy. Just stop every couple humdred miles and run the engine for a little bit.
