DavidandDayle wrote:
I haven't seen a flashlight in any of the lists.
I like the ones that fit over your head and point where you're looking. Sometime in the trip you'll have to go outside and check a propane supply or the circuit breaker or ...
A cheap set of a lot of screwdriver bits. If you wear one out, you can replace it with something sturdier.
Doesn't your cell phone have a flashlight option?
But yeah a basic tool kit and multimeter...and definitely the square Robinson screwdriver bit.
After that, I would keep it simple the first few trips and see what you need.
Chemical tablets for the toilet are a waste of time. Just use lots of water and don't dump unless at least 2/3 full and it's not a problem.
