njtony
Dec 25, 2016Explorer
tv
On both my t.v.s on one channel only I have snow.I am on a cable system and have checked other campers tv. They have a clear channel. All my other channels are perfect. Have turned off heaters. Any suggestions?
wildtoad wrote:
Turn off tv antenna booster and then rescan for channels. The booster interferes with cable. I assume you have set the tv to cable and not antenna.
X2, TV booster blocks reception when you are hooked up to cable.
njtony wrote:
On a cable system. Other campers tv are ok. Have tried rebooking tv same thing. Un pluged anything pu
Plugged in.no luck. It's a local channel. Its weird that only one channel is effected. Guess I just live with it. Thanks to all.
dwayneb236 wrote:
Not sure I understand about the booster being checked. Wouldn't none of the channels be working if the booster was on. He's saying all channels work great other than one. Seems like that's not a booster issue since no other channels are affected.
