water heater
njtony
My Atwood water heater (2013 coach ) has started to emit soot from the exhaust system. What could be the cause ?
6 REPLIES 6
starcraft69
This was our problem take a look could be the same.
http://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/29168353.cfm
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
Old-Biscuit
Remove burner tube
Remove main orifice----soak in alcohol then blow dry (Not with high pressure compressor just whistle)
Clean out burner tube with small bottle brush
Run wire thru combustion/exhaust chamber....tie rag to wire and pull back thru 'U' tube
Install orifice
Install burner tube....align it so it is straight with gas valve/want gas to flow down center of tube not bouncing off wall of tube. If crooked gas/air will NOT mix properly
Check spreader plate on end of tube...should be parallel to end of tube
Light of WH burner....loosen screw on air shutter and adjust air mixture
Close off slots if REALLY LOUD BRIGHT BLUE flame
Open more slots if YELLOW LAZY Flame with soot (unburned fuel)
Flame should be Blue with tinges of yellow tips
Clay_L
There are a number of things that can cause it.
Go HERE for a troubleshooting guide and scroll down to "Erratic burner flame or sooting".
In my case it was a misaligned flame spreader.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
njtony
ok. Will check it out tommorow. Thanks.
wildtoad
As I recall there is an procedure in the manual for cleaning the burn chamber as well as adjusting the flame.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
MFL
Nomad II
Nomad II
It could be bugs, bug nesting, something plugging up the burner pipe, causing a poor fuel/air mixture. You may need to remove pipe, clean out/blow out, something causing an obstruction. You want to see a good mostly blue flame.
Jerry
