yaya's avatar
yaya
2 down towing
Can I use a brake buddy when using a dolly for two down towing. I use to tow 4 down but got rid of my Jeep. I want to buy a tow dolly to tow my Volvo front wheel drive. Thanks
  • Thanks everyone. I thought that was the case but needed some experienced input.
  • Sell your brake buddy and apply the proceeds to a dolly with brakes.
  • Bobbo's avatar
    Bobbo
    The dolly should have the brakes, not the car. Activating the front brakes on the car does nothing since they are not rolling. Activating the rear brakes on the car is trying to pull the car off the dolly. That is considered a bad thing.
  • j-d's avatar
    j-d
    Negative on that. The BB would "step" on the Volvo's brakes but those brakes but those wheels aren't on the ground with the Dolly.
    All you need is a Dolly that already has its own set of Brakes. You can get them with Surge brakes. Those are hydraulic, where the "stepping" on the brake occurs as the dolly pushes forward against your coach as you step on the coach's brakes. Rental trailers and many boat trailers work that way. Or electric brakes like most travel trailers and fifth wheels have. Just install a Brake Controller in your coach.
    Just don't get a Dolly without brakes. Those are available too. You COULD add brakes to one, but it makes more sense to start out with the right kind.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 25, 2026
