pasusan's avatar
pasusan
2 questions about using the pink stuff
I have always been a line blower outer till we got our B (which never seems to get all the water out when blowing). I have a couple questions since I have to use pink stuff in there...
1. Is the pink stuff (I got the Camco Arctic Ban) OK to sit in the toilet or will it be bad for the seal? I can't get the pink stuff out because if I flush - more pink stuff comes out of the lines.
I use the Thetford Toilet Seal Lubricant and Conditioner in our trailer as I don't use the pink stuff in the lines.
2. Will the plumbing at the water inlet be OK since there is no pink stuff in there, I'm assuming there is still water. Or will the water mix with the pink stuff in the lines and then will that be enough to keep it from freezing?
Just trying to be safe...
