Are you also aware you will need a RV30A-15A long ADAPTER to connect your trailer 30A SHore Power Cable to the 20AMP Service 120VAC receptacle at their pedestal.
If you dont have this adapter you can pick this up from WALMART
looks like this... Make sure all three prongs are in good shape - this is the only frame ground you 30A Trailer will have...
I have never had good luck using the small round type RV30A-15A adapters like these. They always get hot on me...
This is what you "don't" want to happen to your RV30A shore power plug due to poor adapter connections...
Again you can run all of the 120VAC items in your 30A trailer using the camp ground 20AMP Service connection including your air conditioner. You just can't have two high wattage items on at the same time as it will trip the pedestal breaker.
I use this type connection to my garage 120VAC receptacle at home all the time with my t30AMP trailer. It might be a good idea to bring along a RV 120VAC VOLTMETER like this one plugged into a easy to see 120VAC receptacle inside your trailer to keep an eye on the 120VAC VOLTAGE. This is a neat AC meter to have as it has the SAFE ZONE SCALE printed in "GREEN". DO not run hig high wattage items if your 120VAC level is outside this printed safe zone.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
