luberhill's avatar
luberhill
2013 Onan gen ? Fuel filter ??
Ok I’m changing the oil, I don’t see a fuel filter to change ??
  • DrewE wrote:
    At 100 hours, you probably don't need to do anything.
    x2
  • At 100 hours, you probably don't need to do anything. What you're seeing is most likely the fuel pump, I suspect--typically a metal cylindrical object with the fuel line going in and out and (if you look closely enough) wires to power the pump.
  • I don’t see anything, except buried in the back corner of the gen cabinet looks like maybe a metal one,, no clue how to get to it or with 100 hrs if I even need to
  • Can you follow the fuel line back to the gas tank?
    I know the older Onan generators have a small filter where the fuel line enters the carburetor.
  • Not enough information. Need model and gas or diesel. Did you check out on the onan/cummins website for information?
  • I don't know about a 2013 Onan, but when I had a 1996 there was a fuel filter. It was located at about where the fuel line enters the genny enclosure. I bought a new fuel filter, but sold the rig before I installed it.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
