- willaldExplorer II
mowermech wrote:
you could go to NSA and get the Ready Brute integrated towbar/braking system. for under $2000, get the towbar brackets, and be much better off, IMO....
..This is what I would highly, highly recommend. Can actually be purchased for MUCH less than $2000, current price on NSA's web site is $1275. You can order it from hitchsource.com HERE for even less than that ($1175), and free shipping is included. :)
IMO you just can't beat getting a tow bar AND braking system for that $$. With any separate tow bar and 'electronic box' type brake system, you'll easily pay over $1000 more than that, total. And thats without even getting into how much better and more reliable the Readybrake system is over so many other options.BUT, as bumpyroad said, READ the Owners Manual, and FOLLOW the instructions contained therein! If the book says DON'T TOW IT, you are on your own!
Good luck.
...Its already been established that the vehicle in question (Chevy Traverse) IS flat-towable, per the manufacturer. We can stop 'preaching' (beating the dead horse) about the owners manual now, really. :) - mowermechExplorer
lanerd wrote:
Well, let's see. To start off, you'll need a base plate ($350), Tow bar ($900), Light kit ($50), and a supplemental brake system ($1000). Labor to install all of the above (~$1000).
Roadmaster and Blue Ox are probably the two favorite brands here for the base plate and tow bar. Supplemental brake systems can go from a box in the floor board (Brake Buddy) to a built in system on the tow bar (Ready Brake), to systems that use the air from the motor home (Air Force One) and also those that have small vacuum pumps that use the toad's power brake system (US Gear's Unified)....and a multitude of others.
All can be installed by yourself if you can read instructions, have a few tools, and have the time to spare.
Hope this is what you were looking for.
Ron
Or, you could go to NSA and get the Ready Brute integrated towbar/braking system. for under $2000, get the towbar brackets, and be much better off, IMO. The lights can be hooked up for less than $100.
Or, you can get the Ready Brake from NSA that can be used with ANY towbar, then go to Walmart and get a Reese fixed arm adjustable width towbar for about $165. Yes, it is "inconvenient", but it does the same job as the very expensive towbars! I used one on Jeeps for years.
Your options are nearly limitless. Have fun shopping.
Good luck. - jerseyjimExplorerFigure a ball park of $1000. IMO, go for the BlueOx baseplate with the removeable tabs.
I use a RoadMaster telescoping towbar. 5000 pound max. If I were buying new, I would investigate the "ReadyBrake" towbar. Really interesting. I would choose the "ReadyBrake" over all the other systems that require battery power and, like the above post from CA TRAVELER can give you problems you don't need.
You can get the brake light/rear running light diode kit or go for the magnetic lights. I've used both with no problems.
But you FIRST must read the OWNERS MANUAL for your car. If it says you can tow 4-down...go for it. If it says you cannot tow four down, you're done.
g'luck! - BiocruiserExplorerAnother vote for the Ready Brute Elite. We've traveled over 10K miles over the last 10 months and I found the Ready Brute to be very easy to use. The braking system works flawlessly once it is properly adjusted. I added a turnbuckle to the brake cable to aid in adjustment, and I also have a light on my dash which shows when the toad is braking. I also added a Toad-charge which was required to keep the battery charged.
I have a Demco baseplate which works well with the Edge. I would also consider Roadmaster next time depending on what Toad I have. We used a quality body shop to install the baseplate and lighting kit and they did a great job. - willaldExplorer II
beagles7278 wrote:
Thanks again for all the responses, still researching my options. Looking at the Ready Brute Elite tow bar, looks like I get the tow bar plus brake system in one. Anybody have this?
Yep, thats what I have, and IMO it just can't be beat. Very simple, works great, and costs about half overall what you'd pay for any other separate tow bar and braking system.
You'll find almost nothing but glowing reviews on here, for the Readybrake/ReadyBrute system. - conmotoExplorerI have the Blue Ox Patriot now and I believe the next system I get will be the Ready Brute. I have read many good things about that set-up. Good luck!
- beagles7278ExplorerThanks again for all the responses, still researching my options. Looking at the Ready Brute Elite tow bar, looks like I get the tow bar plus brake system in one. Anybody have this?
- Nvr2loudExplorer IIThe Traverse, Acadia, Enclave, and Outlook are all designed for 4 wheel down towing, in both FWD and AWD versions.
Consult the owners manual under towing the vehicle to find out more. - CA_TravelerExplorer IIIOP My input, research Roadmaster, Blue Ox and Ready Brake. What I did below:
1. I would not have a tow bar that is not adjustable for hookup. It's a pain to align it for hookup. Nor would I have a vehicle mounted tow bar as I don't want to have to remove it or drive around with it on front of the car.
2. My 04 tow bar was a RM Falcon 2 and I quickly learned that it easily binds for unhitching. I learned to mostly avoid the binding but eventually upgrade to the Falcon All Terrain.
3. In 04 I got the RM box brake. As we began traveling more it became an increasing pain to install/uninstall.
4. Hookups are easier with my RM Invsibrake. There is absolutely nothing to do to activate the Invsibrake, it's completely automatic.
My advice is to consult your crystal ball, figure out what type of towing you will be doing then buying equipment to meet that need including long term. That may not be the cheapest choice.
A lot of people like the Ready Brake. It's cheap and works well from all accounts.
I also upgraded from the 4 wire cable for the lights to a 6 wire cable. The 5th wire is a battery charging line. The 6th wire connects the toad brake lights to a light on the MH dash. I know when the toad brakes are applied.
After connecting the car DW checks the turn signals and brake lights for both vehicles before we travel. Apparently most folks don't check. We use handheld radios for this task. These are the same radios I use to find DW when she gets lost in a big box store. :B
Some history: Our 04 CRV had a failed battery in 04 and 05 both on the road and replaced under warranty. Current battery is on year 8. Left the key on one night while connected to the MH. First think I did next morning was to put the car in park. BIG OOPS as the car is now locked in park, cannot shift to neutral since the battery was dead. And the jumper cables would not reach the car. :( - 2gypsies1Explorer III
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
