Motor_City_Swag
Jun 26, 2017Explorer
2017 Ford Explorer mass flow indicator code
I follow all of the instructions in the Ford manual regarding flat towing a 2017 Ford Explorer with auto trans and 3.9l v6 engine. I run the engine for 5 minutes, put the trans in Drive then reverse then neutral, shut the engine off and open the knife switch on the negative battery cable. When I am done flat towing I the close the knife switch and put the car in park and star it. The problem is a 0068 mass flow indicator code pops up everytime, I clear the code and during normal driving every thing is fine it doesn't come back this only happens when I am done towing. Has anyone else experienced this code coming in or can explain it?
