- bartlettjExplorerMine is pretty sloppy on my GMC, too, but I don't really notice it when under way.
Lynnmor wrote:
+1
Buy the correct shank, that adapter is best used for a small utility trailer.
Get the right stuff. Adapter is for temporary use only.- Grit_dogNavigator IIINews flash! It's ALL trucks, IMO. All will have a little slop in the hitch/receiver connection. If it bothers you, NEVER tow a pintle hitch! Lol
Length of drawbar either minimizes or exaggerates it too. Long draw bars for wdh setups or hitch extensions exaggerate the "slop". They even make little kits to snug up the hitch for those that find it annoying.
Regarding the sleeve, put it behind the seat for a rainy day and get a 2.5" hitch before you bend a pin and or Waller out the holes in the receiver. - takenExplorer IIEven with a matching shank, the 2017+ Ford receiver's are very sloppy in both the 2.5" and 3" variety. Yes, it's normal for them but not right IMO.
- mkirschNomad IIEither that or get yourself a 9" or 12" Curt weldable hitch tube, drill another cross hole, and use that for the adapter sleeve. It is a much better fit, and supports the shank better.
- LynnmorExplorer IIBuy the correct shank, that adapter is best used for a small utility trailer.
- SidecarFlipExplorer IIIRun some weld beads on the reducer and grind them down to fit snug.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 29, 2025
