tensch
Oct 15, 2019Explorer
2019 F-150
Any issues pulling a 3000 lb 2014 Shadow Cruiser (18') TT with a new 3.3L Ford F150 Supercrew? Thanks for your thoughts.
JRscooby wrote:
A 600 lb TW needs a WDH on a half ton?
wing_zealot wrote:
Actually the first version of the Triton V10 had between 305 and 310 horsepower and 420 to 425 lb-ft of torque.
carringb wrote:Actually the first version of the Triton V10 had between 305 and 310 horsepower and 420 to 425 lb-ft of torque. Clicky But in any event, that 3.3L isn't anything more than a grocery getter. If you want a grocery getter, it will work just dandy. If you want a tow vehicle, get a real engine, the 3.5L ecoboost (best $600 investment you can make in a truck). Just my Opinion, Yours may vary.
Wow. So now everybody thinks 290 horsepower can't pull 3,500 pounds????
That's more horsepower than the original Triton V10 made!
Sure, the turbo motors are far superior, but I don't think that part of the question.
OP - You'll be fine. It'll be spinning fast at times and you won't be able to tow in 6th gear, but it'll get the job done easily.
jfkmk wrote:
The 3.3 is not an ecoboost engine. A quick search shows that a properly equipped 3.3 has a max tow of 5,000#. You may want to rethink the truck or the camper.
JRscooby wrote:Second Chance wrote:
A quick search would indicate that the 3,000 lbs. you quote is empty. GVWR for the trailer is 5,835. Use 10% of the GVWR of the trailer to estimate tongue weight and add 75 - 100 lbs. for a good WD hitch. Now... what does the payload sticker on your truck say? Remember that gas, occupants and "stuff" all count against the truck's payload. The EcoBoost is a good motor. With 1/2-ton trucks it's all about payload.
Rob
Good thing our tax money keeps the price of gas down, some need a N14 to pull a popup
