Furch5263's avatar
Furch5263
2100 keystone cabana no sway or load leveling do i need it?
Howdy folks, hoping someone can point my brother in law in the safe direction. He has a 2000 keystone cabana hybrid. He got a great deal on the camper. Only question i have is does or should he have a load leveling and anti sway hitch. It seems to me that he should. His truck is a 2004 sport trac. It came with out the hitch. We put that on so i am also concerned about not having a tranny cooler. Also, not sure this truck is big enough to tow this trailer. Just figured i would ask. Looks like to me the truck might be on the max limit side. Thanks any help would be greatly appreciated. Furch5263
  • I agree with you guys about the whole new truck idea. Just trying to help him out. I did not know they sold a light duty level hitch. Very interesting. Also, not sure if he has the rv manuals but i will tell him to look. Great suggestions. I agree that he should have the hitch no matter what. It can only make it safer, and easier to tow.
  • The Sport Trac is essentially a Ford Ranger chassis, is it not?
    If a Ford Ranger with the "big" V6 can't safely and comfortably tow 3000lbs without spending more than $300-$400 on a receiver and transmission cooler, nothing can. You aren't going to find much of a "TRUCK" for $300-$400.
    A weight-distributing hitch is ALMOST always a good idea. HOWEVER, some small popups and travel trailers are not designed for the forces of a weight-distributing hitch. You need to refer to the owner's manual for this travel trailer to see if this is the case.
    Sway control is definitely a good idea regardless. Better to have it and not need it than need it and not have it. Keep in mind, sway control is not a solution for "known" sway. If you have a sway problem, fix it first, then add the sway control for UNknown sway, such as crosswinds, uneven road surfaces, etc.
  • I have had many tv's in my 70 some years and I have to say, never ask a small boy to do a man's job. with out the tranny cooler he will be looking at putting a new tranny in sooner or later. with that cost in mind he might as well buy a truck that can do the job in the first place. he will be putting in more money than the truck he has is worth trying to get it up to a good towing capabilty.. which is not a good idea, just take the money he is going to spend on this truck and get a TRUCK
  • From what I can gather on the net, the trailer has a GVW of a little over 3000lbs and should have a tongue weight when ready to go camping of around 450-500lbs.
    The Sport Trac, is a small truck with a 4.0L V6 engine. If it were me, I would use a simple 500-600lb weight distributing hitch and the single friction sway control that comes with that hitch. You can purchase that combination pretty cheaply and it should do the job.
    Barney
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
