mowermech
Nov 23, 2019Explorer
Older manual transmission Subarus were towable, I have read, according to the Owner's Manual. Newer Subarus are not, even manual transmission models.
Regardless of the vehicle you are interested in, always find "Recreational Towing" (or something similar) in the Owners Manual, read and follow the instructions.
Generally speaking: No vehicle that has a CVT is towable. Manual transmission does not necessarily mean it is towable. Automatic transmission does not necessarily mean it is not towable. If there is no warranty, anything can be towed, if you are willing to accept the fact that the transmission might be destroyed due to lack of lubrication (it might take a while, but eventually it will probably happen). If there is a warranty, but the Manual says "do not tow with all wheels on the ground", but you do it anyway, the warranty on the transmission will likely be void.
As for "best towed", I don't believe there is a "best". There is only what YOU like. For instance, years ago the most common "towed" was a Volkswagen Beetle, the original. Very light vehicle, fun to drive, inexpensive towbar readily available, just hook it up, put the tranny in Neutral, and go. No limitations.
Good luck in your search for YOUR "best toad".
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
