Mar-13-2017 12:38 PM
Mar-15-2017 03:03 PM
Lantley wrote:
The point of carrying a 30 amp cord is so you can avoid using the much heavier 50 amp cord if you don't need to.
Mar-15-2017 08:35 AM
bucky wrote:
Because a percentage of humans will argue with a tree.
Mar-15-2017 05:49 AM
Why get out the heavy 50 amp cord if you only have 30 amp worth of power available?
Adapters do not eliminate the heavy cord from the equation. The OP's goal is to use the lighter cord when possible. The lighter 30 amp cord is available
x2
why is this "fact" so difficult for some to grasp?
bumpy
Mar-15-2017 05:01 AM
Mar-15-2017 04:57 AM
Mar-15-2017 03:57 AM
Mar-15-2017 02:34 AM
Mar-14-2017 09:17 AM
Mar-14-2017 07:12 AM
Mar-14-2017 07:07 AM
fj12ryder wrote:Bumpyroad wrote:I don't, never needed it. It could happen but hasn't so far in about 10 years of periodic travel. It certainly could, but not so far.lawnspecialties wrote:
I have both a 30A cord and a 30A adapter. But the thought of dragging that 30A cord around means it stays home 100percen of the time. I use it when the camper is in the driveway being loaded up for a trip. But it goes in the house garage before we leave.
you don't carry a spare additional cord?
bumpy
Mar-14-2017 07:03 AM
Mar-13-2017 09:52 PM
Us out West wrote:Lantley wrote:Us out West wrote:rk911 wrote:tim1970 wrote:
I was wondering if anybody that has an RV wired for 50amp service carries a 30amp cord for when they know they will be at a campsite that only supports 30amps. It seems like it would be better than having to use the large 50amp cord. I guess I also need to know if you can even buy a 30 amp cord that will plug into an RV designed for 50 amps. (Is the connector the same?)
Thanks
Tim
we carry a 50==>30 amp dogbone adapter for use in parks that don't offer 50-amp service. I doubt you'll find an RV that is wired for 50-amps but will let you plug in a 30-amp cord. that's what the adapters are for.
Same....thanks.
The 30 amp to 50 amp cord does exist no adapters needed.
Yes it only delivers 30 amp but it connects to the standard 50 amp RV twist connection
No need to carry extra power chords.
If the pedastal has 30 amp but not 50 amp here is what we have.
30M/50F AMP 18" Dogbone
Mar-13-2017 08:20 PM
Thanks
Tim
Mar-13-2017 08:02 PM
Thanks
Tim
Same....thanks.
