mgssrs's avatar
mgssrs
4.5 inch LED
Does anyone have a part number for the 4.5 inch LED bulb over the table in my Sunset trail? I haven't be able to find one with the same style mount.
  • 4x4van's avatar
    4x4van
    The picture on the other forum that you linked to still doesn't help us, as it shows only the housing and lens, not the bulb.
  • Tyler0215 wrote:
    Google is your friend.
    So are the people on here. No ink was killed by the OP. ;)
  • loggenrock wrote:
    Is it something like this? http://tweetys.com/overhead-light-led-nickel.aspx
    If you have some burned out LED chips, I might suggest this:
    http://www.cabinbright.com/shop/new-products/itc-fixture-replacement-led-set/?mc_cid=b163d6dce7&mc_eid=f4d0084b67 - less expensive, less power drain, certainly better LED chips than on the original one! Also check JR Products - they make a lot of the RV components. ST
    Thanks for your reply. I couldn't get a picture posted here so I'll try a link to another post I made. I was hoping someone else had replace one on a Sunset trail and would know the part number. http://www.crossroadsowners.com/forums/f25/4-5-inch-led-13178.html
  • SCVJeff wrote:
    need WAY more info than this.. a picture will answer everything
    Sorry I was camping at the time and posted from my phone so I couldn't remember how to add a picture. I am home now and still can't get a picture added. When I click on the link I found in my search Norton says it is a dangerous site and blocked. Any advice on adding a picture?
  • Is it something like this? http://tweetys.com/overhead-light-led-nickel.aspx
  • Is the bulb marked in any way? Is it a single post or double? Go to the campling world site and search led bulbs.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 25, 2026
