cattledog04's avatar
cattledog04
5th Wheel Hitch Adapter for Puck Systems
Any idea if there is a universal adapter that a B&W hitch would work with for a puck system? I have a 2020 Chevy HD on order and my Patriot is new; I'd hate to have to buy a new hitch.
  • cattledog04 wrote:
    My last 2 hitches have been sliders, and my trucks are short beds. Not once have I ever used the slide. Whats the opinion about it being a nessesitiy? I'm leaning on not buying one.
    I got into a forest service campground with a very tight turn to get back out. Without my slider not sure I could have got out.
  • I've been towing FWs with 6' 9" bed Fords since 99 with non sliding hitches. The GM trucks have the longest distance from rear axle center to cab, so should be a non issue.
    Jerry
  • My last 2 hitches have been sliders, and my trucks are short beds. Not once have I ever used the slide. Whats the opinion about it being a nessesitiy? I'm leaning on not buying one.
  • It exists, but it isn't cheap:
    Demco 5th Wheel Rail Adapter for Ram OEM 5th Wheel Towing Prep Package - 25,000 lbs. Currently listed for $540. (Which is crazy, I spent $406 last August.)
    By the time you buy that, you could likely sell your Patriot and buy the Companion hitch for your truck's pucks.
  • MFL wrote:
    Cummins12V98 wrote:
    WAYYYY better off selling your Patriot and buying the B&W puck hitch to fit your truck.
    I agree...while the Patriot is a great hitch, the direct fit to pucks is a better idea. You will add a couple inches of height by using an adapter, that you likely don't want.
    Jerry
    YES, good point on the additional height!!!
    Jerry
  • Big1's avatar
    Big1
    Yep, I bought a B&W puck hitch for my new ram it's not the slider for my SB but you can turn the pivot leg in reverse and get another 2' to 3' out of it but I'm still using my head. The puck for my truck was $697.00 I have it now but just haven't put it together.
  • WAYYYY better off selling your Patriot and buying the B&W puck hitch to fit your truck.
  • rhagfo's avatar
    rhagfo
    stickdog wrote:
    Give B&W a call.
    I believe that B&W sells the puck base for about $700, your head will fit. it will fit the pucks.
    Give B&W a call.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
