hmknightnc
Jun 29, 2014Explorer
Couple observations: 1) you are just over the TV GVWR but well within Axle ratings so no real problem there but you are close to or at maximum weight for that truck so it is going to handle like a heavily loaded truck because it is.
What was your TV individual weights without the RV attached? Curious how much your front axle weight changed. It should have gone up slightly, if it didn't your FW hitch is not far enough forward of your rear axle.
Couple suggestions:
- verify your FW hitch is installed properly via the weight measurement I suggest above. Your front axle doesn't seem heavy enough but I could be dead wrong with that gas engine.
- your fully loaded, if your not already doing it, slow down hitting bumps, entering bridges, and etc
- verify your TV tires are heavy enough, load range E LTs rated around 3k#s
- new heavy duty shocks
Couple suggestions:
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
