7 way Plug tester
Bob_Vaughn
I have a pickup truck with a 7 way plug in the bed and one in the bumper. When I have some one activate the brake control the green light for the brakes just flickers on the bumper and the one in the bed I can not see a light. So I am assuming that I am not getting full power to the brakes on the trailer. Should I hook a ground wire from the frame of the trailer to the frame of the truck to get a good circuit ? Or am I panicking over nothing??
7 REPLIES 7
Bob_Vaughn
I took the 7 way plug from the bumper and discovered that the brake wire that had been spliced in for the bed plug had broken off the connector plus it is way too small guage wire. The company that installed the hitch and plug did a crappy job. The splice job looks like a job that a child would have done......So now it is going to cost more money to have it fixed.....
Chris_Bryant
Some controllers have to have a draw (load) on them- a test light will not do.
-- Chris Bryant
Bob_Vaughn
Gene&Ginny wrote:
Bob Vaughn wrote:
... Should I hook a ground wire from the frame of the trailer to the frame of the truck to get a good circuit ? ...
One of those wires in the 7 pin is a ground that connects the frame of the trailer to the frame of the tow vehicle. No reason to add another.
I do not have the tow vehicle hooked up to the 5th wheel.......
Gene_Ginny
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Nik
Test with the manual slide on the brake controller, all the way over.
Website: http://www.nikandjune.com
Current RV: 2003 Fleetwood Terra 26Y
Previous RV: 2015 Wildwood X-Lite FS T192BH
Previous RV: 1985 Itasca Sundancer (24')
Previous RV: 1984 Starcraft Starmaster 21
remdog_1
Also need to check to see if fuse needed under hood. Some tow packages require 20 or 30 amp fuse. It all depends on type and year of vehicle. Also check ground. 90% if issues is bad ground
RoyB
When stopped most newer trucks will not send BRAKE CONTROL DC VOlTAGES when pressing the brake pedal. My 2010 Ford truck has to be moving at least 10MPH before any brake control voltages is sent to the trailer brakes.
Using the MANUAL SLIDER LEVER however overrides this feature.
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
