โJun-10-2014 03:36 PM
โJun-11-2014 09:00 AM
โJun-11-2014 06:26 AM
โJun-11-2014 05:28 AM
โJun-11-2014 05:07 AM
tenbear wrote:
How dim do you want to go? Do a search on eBay for "T10 led warm white". Something equivalent to the 921 bulb would have about 24 5050 leds, so 6 5050s would be about 1/4 as bright, and so on. Some use 1210 (3528) leds which are about half as bright as the 5050 led. Take your pick.
โJun-11-2014 05:02 AM
โJun-10-2014 06:55 PM
Reese Dual Cam Straight Line HP Sway Control
โJun-10-2014 06:33 PM
โJun-10-2014 05:15 PM
โJun-10-2014 04:44 PM
mbopp wrote:
The 921 bulb is rated at 21 candlepower.
A 922 is 15 C.P.
A 920 is 10 C.P.
The smaller 194 (same base) is 3 C.P.
I replaced my incandescent bulbs with 1210-36 LED panels.
โJun-10-2014 04:17 PM
โJun-10-2014 04:13 PM
Fastfwd75 wrote:
I find that the lights are much too bright at night when I just need to see enough to move around. What are compatible lights to the 921 socket that would put out less light or is there an easy way to add a dimmer?
โJun-10-2014 03:42 PM
