darober's avatar
darober
a/c unit
I have a class a motor home with two a/c units
my problem is the font air unit will kick the generator off when the compressor try to come on
any help on how to repair ?
  • Happens to ours. Discovered genny not powerful enough to support the extra draw on its power when A/C tries to power up.
  • are you sure the gen will handle 2 ac's?Does the ac run on shore power?
    Its been awhile since I worked on these small ac's but lean towards a bad "run" capacitor as this must be good to START.
  • Probably the start cap. A visual inspection of it would show if it's bad.
  • Probably the least expensive attempts to fix the situation are replacing/add a start capacitor. If the unit doesn't have a start capacitor, or if the one currently installed has degraded, adding one may take enough load off the generator to prevent it from becoming overloaded and shutting off during A/C start-up.
  • Need more information. What size A/C units, what size is the generator, and what else is on when trying to turn on a/c?
    RV information may also help.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
