- LwiddisExplorer IIMore good examples of why I drive 55 when towing.
- TrackrigExplorer IIIt's interesting that on the third accident that the guy was towing an empty car trailer when it happened.
Bill - carringbExplorer
Bill
Looked like maybe that flatbed had been modified with a tail extension? The tail end wasn't the same material as the rest, but it didn't look like a dovetail. Might have had negative tongue weight from the mods? - Johno02ExplorerIts called "crack the whip".
- gboppExplorerPeople who ask if it's okay to haul passengers in a TT should watch this video.
I wonder if the boat didn't have safety chains? - _tpc_ExplorerHate watching those videos. I understand its to show how serious this kind of stuff is, but I feel bad that these folks never knew, or just chose to ignore things. Or got told bad information.
I've rolled up on some aftermath before, thankfully nothing too serious, but I always wonder "why" to a multitude of things. Seems like there needs to be a safety class and some sort of certification. - rockhillmanorExplorerX10!
THAT video should be in each and every RV dealership
____________________AND___________________
It should be mandatory for a prospective buyer to watch before purchasing a TT.
Especially when a salesman states "sure, your truck can tow that". - blt2skiModeratorThe boat went sliding away with the tail on the ground. So probably no hitch weight, or very little.
The others also probably had to little hitch weight.
Also, one of the setups was a dually. So for those saying a dually is best, better, bestest for handling sway like this. That part of video blows that theory apart! If you have a trailer going side to side, your screwed. If you get back or too somewhere, with sway issues, time to figure out what is causing said sway, fix it, then add the sway bars.
my 02 on this video.
Marty - RCMAN46ExplorerInteresting not a single 5th wheel was shown.
The boat incident shows why good safety chains are required in most if not all states. - sch911Explorer
Yup. Fifth wheels are far more immune to this issue since they pivot over the axle centerline.
I'm not a fan of TT's for this reason. If I had to use one it would have a Hensley hitch...
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
