WinterRV's avatar
WinterRV
Aftermarket Integrated/Permanent Dehumidifiers?
I am looking into getting a travel trailer ready do to some dry camping in cold winter conditions (think trailheads in Montana, Idaho, Wyoming) and as such, will be keeping the trailer pretty tightly sealed. I am worried that moisture from cooking, showering, and drying wet gear will start to build up. Are there any options for dehumidifiers that are not portable? The bathroom will be my primary concern since I plan on drying gear in the shower. As such, I think I value drying power over quietness. Googling did not yield much. Is anyone aware of something that fits my needs?
  • GordonThree,
    I sometimes have to run a humidifier in my RV in mid winter. But it is MUCH colder here and much drier to start with.
  • pianotuna wrote:
    What is needed is to keep the interior walls above the dew point. Opening a roof vent helps greatly with that. Opening a window adds the possibility of a chimney effect. The R.H. of the incoming air plummets when it is raised to a warm interior temperature.
    That advice does nothing for me. I can have both roof vents and a big window wide open and still have condesate on the walls and windows.
    The electric dehumidifier works like magic,
    In very cold weather I'm either on shore power or running a generator full time, so the load on the batteries is minimal.
  • What is needed is to keep the interior walls above the dew point. Opening a roof vent helps greatly with that. Opening a window adds the possibility of a chimney effect. The R.H. of the incoming air plummets when it is raised to a warm interior temperature.
  • You will have moisture in cold weather no matter what. Pay special attention to outside walls, back of closets etc where air doesn't circulate well.
  • ktmrfs's avatar
    ktmrfs
    well, the AC unit is a dehumidifier, but that's likely not an option in the winter.
    I'd go with a portable compressor unit that also has a drain fitting and just have it drain into the grey tank or on the ground.
  • never heard of a built in dehumidifier for a trailer. I suppose they probably exist as part of an HVAC system for a big 5R or class A?
    Get a 90+ pint compressor driven free standing unit. Plumb the drain through your floor (with heat tape), so you don't have to worry about emptying the bin every few days.
    Mine works great in the winter, and in the summer - helps the rooftop AC work better when it's muggy. Even without drying clothes, just me and the dog would steam up my little trailer in no time just by breathing / sweating.
    Edit: the do exist, but wow the cost!
    Aprilaire inline dehumidifier
    Just plumb that into your duct system I guess?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
