- fj12ryderExplorer IIILOL
- Cummins12V98Explorer III
fj12ryder wrote:
Let's not get too carried away. :)
Hey I can dream..... - fj12ryderExplorer IIILet's not get too carried away. :)
- Cummins12V98Explorer IIIReading the thread from top to bottom I assume the same Barney.
But it could mean he agrees with everything i say.:B - BarneySExplorer III
deltabravo wrote:
Lwiddis wrote:
I too agree with Cummings.
?? Not sure what that refers to.
I'm sure he is referring to the statement that Cummins made. "First thing put a set of Bilstien shocks on it. Inflate tires based on load using weight/inflation chart for your tires."My bold.
?? Not sure what that refers to.- Cummins12V98Explorer III
snowpeke wrote:
Cummins12V98 wrote:
. They have many different ones do you have a a favorite? How much are they?
Air bags can help but do the above FIRST.
Depends on what color you like. For stock trucks 4600 are yellow and light blue. For stock to 2" lift 5011 are silver and black. Basically the same shocks.
4600 on my stock front 15 DRW and 5100 on my 01 with 2" lift front and no lift rear. - Grit_dogNavigatorAnd yes, airbags eventually wear out and pop or maybe leak if the line gets chaffed. Using that as a reason to not use them is as silly as saying, "Why use tires, they just wear out or blow out?"
Last set, on our 07. bought them used in 2013, so presuming they were at least 10 years old before one of them popped.
I've split Timbrens in half too... - Grit_dogNavigator
Maybe I should have been more deliberate....
E x p l a i n y o u r p r o b l e m i f y o u w a n t a c c u r a t e a d v i c e.
Oh and use the internet for easy functions like looking up the applicable part and it's price. - Cummins12V98Explorer III"I'm not a fan of Bilstien shocks but if your '02 truck has the OEM shocks they would work better."
I'm curious what aftermarket shock do you like?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
