mike-s
Sep 09, 2017Explorer
Blacklane wrote:The thermal mass makes no difference to the cooling ability. It just means it will take longer to heat up AND longer to cool down.
The new aluminum cover is indeed much thicker than the stamped steel stock cover. That gives it more thermal mass and makes it slower to change temperature. Additionally, the aluminum cover is designed to hold 0.5 quarts more fluid, which also adds thermal mass.
Blacklane wrote:Black does help with radiative cooling. But the vast majority of the cooling here would be through convection - lots of surface area, lots of moving air when going down the road.
painting the surface black improved the thermal performance.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
