jerem0621
Feb 17, 2015Explorer II
A question that is often asked on this forum is how much can I tow?
While this question does not have a simple answer there are some tools you can use to help understand the variables to accurately answer this question for yourself.
I must warn you right off...many people are shocked to find that their tow vehicles can't safely tow trailers that may be under their manufacturers tow ratings. Be prepared for that reality...
The Lowest Component Capacity is the component in your towing system that runs out of capacity first... that is your real limit.
First, you need to do some homework... big time homework... and get familiar with a lot of terms and equipment.
Note: This should be REQUIRED READING for anyone new to towing (or to get freshened up on your terms and understanding)
Click on this Link to U-Hauls Towing Glossary and READ EVERYTHING... read every single link.. then read it again.. make sure you understand the concept of these terms and the equipment listed in this link.
Now... We need to find out how much your available payload for your vehicle is and how much your excess axle capacity is.
Determining Available Payload and Axle Capacities
Take a look at this chart and plug in your answers on a separate piece of paper
Now that you know how much payload you can carry in addition to your family we need to find out how much of a LOADED trailer you can tow with your current vehicle AND carry the tongue weight or the fifth wheel pin weight.. depending on the type of RV you prefer.
Remember, nobody tows an empty RV to the campground...FORGET about unloaded trailer weights in the Brochure... Add at least 1000 lbs to 1500 lbs to the unloaded weight of the trailer you are looking at.. that will give you a closer approximation to the loaded trailer weight.
Rules of Thumb
When Guesstimating travel trailer tongue weight or fifth wheel pin weight, without weighing the actual trailer we can use a "rule of thumb" to give us an approximation to the likely heaviest tongue weight or pin weight the trailer will have.
For travel trailers the rule of thumb generally is 13% of the LOADED trailer weight will be the trailer tongue weight
For fifth wheels the rule of thumb generally is 25% of the LOADED trailer weight will be the trailer pin weight
I will be the very first to admit that not all Travel Trailers have 13% tongue weight... some have 10%, some have 16% or more. Not all fifth wheels have 25% pin weight, some have 19% or 22%... etc. etc... the purpose is to give you a general idea of a likely weight of trailer you can safely tow without overloading your Tow Vehicle.
The charts below let you take your available payload... and/or your available rear axle capacity and see how large of a TT or Fifth Wheel you can tow AND carry the tongue weight using the above rules of thumb.
Travel Trailers
Fifth Wheels
Don't forget Your Gross Combined Vehicle Weight Rating(GCVWR)
This number should be in your owners manual.
Add your loaded vehicle weight and the loaded trailer weight that you are considering together. This number is the gross combined vehicle weight... is this number UNDER the number in your manual? Yes? GREAT!... No? You need to look for a lighter trailer that will fall under this Gross Combined Vehicle Weight Rating.
Need to know how much a trailer tongue/pin weight will be with a different %?
We have a chart for that ;)
and lost of disclaimers.. etc etc etc
Max Trailer Tow Rating
One situation that some operators run into, especially with dually, HD pick up trucks is that they have enormous amounts of payload... so using the chart above they could just about pull the moon...
Not so fast.... there is still the trailer tow rating...
so even with enormous payload ratings.. the trailer tow rating should be complied with.
Finishing Up
If you can tell from all the math and the numbers above the real limit to how much you can tow is the component that runs out of capacity first.
I will call it LCC (Lowest Component Capacity)
DISCLAIMER: This is free advise...I am not a professional trainer in any position to CERTIFY your rig as good to tow. Its YOUR job as the vehicle operator to ensure that your Tow Vehicle, Hitch, and Trailer all all matched together properly, maintained properly, and the rig is operated sensibly.
DISCLAIMER 2: ... You and ONLY You as the operator are responsible for the safe operation of YOUR vehicle.
Thanks and see you on the open road!
Jeremiah
Rules of Thumb
Travel Trailers
Fifth Wheels
Finishing Up
- If you run out of payload then this is the LCC
- if your rear axle runs out of capacity then this is the LCC
- if you run out of receiver capacity then this is your LCC
- if you run out of GCVW rating then this is the LCC
- if you run out of trailer tow rating then this is the LCC
- if you run out of tire capacity then this is the LCC
Jeremiah
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
