- JackalopeExplorer
msmith1199 wrote:
The 4x4 Toyotas do have a neutral position in the transfer case and I was told by a salesman and his boss that you can tow it four down and in neutral just like the Jeep and Dodge's. I pointed out to them that the owners manual said the vehicle could not be towed four down. They said Toyota just put that in there for liability purposes. So I told them I'd buy the truck under the condition that we have a side contract that states that I intend to tow it four down and that the dealership agreed to take full responsibility in the event of any issues regarding warranty work that may be voided because of my towing it four down. They would not agree to such a contract so I didn't not buy the truck. Got the Dodge Dakota 4x4 instead and it is towable four down and it is approved by Dodge to be towed that way.
The Toyota cannot be towed. Without the transmission turning, the output shaft receives no lubrication and will burn up being flat towed. - moose888ExplorerI checked it out when I first started looking for something to tow. I have a 1992 toyota truck 4x4 5 speed V6 auto hubs said it can't be towed.
- myerscExplorerI tow a 2003 toyota tacoma v6 crew cab automatic 4 wheel drive. I use a remco drive shaft disconnect that I found used for half price of a new one. It works great and I've had it a few times on some hairy off road tours with no problems.
- j-dExplorer IISame as our Frontier. Only difference is Nissan says OK to tow the manual transmission-equipped Frontier and Toyota said don't tow any of their Tacomas. I would venture, however, that there's not much reason not to. Nissan wants the engine idled in Neutral every several hours. I forget how many and won't worry about it since we don't go that far.
- FlanzExplorer
j-d wrote:
-paul, you tow with transfer case 2WD High and manual transmission Neutral, correct?
If so, that matches Nissan's instructions for manual transmission Frontier, but doesn't help (read that "doesn't allow") towing with automatic transmission.
That is correct. The transfer case is in the 2WD High position and the manual tranny (6 speed) is in neutral. Also, I need to keep the key in the ACC position. The truck does not clock any mileage while in tow. - j-dExplorer II-paul, you tow with transfer case 2WD High and manual transmission Neutral, correct?
If so, that matches Nissan's instructions for manual transmission Frontier, but doesn't help (read that "doesn't allow") towing with automatic transmission. - FlanzExplorer
wbrowning wrote:
2004 Crew Cab 4x4 V6
I currently flat tow a 2005 Tacoma 4X4 xtended cab, six speed manual tranny. No problems at all. Been doing it for about 4yrs.
-paul- Crown79Explorer
Did you disconnect drive shaft or just put transfer case in 2nd and transmission in neutral . Key on in accessory. ???
- BumpyroadExplorer
wbrowning wrote:
Thanks for the replys guess I will look for a different rig
a wise decision.
bumpy - moishehExplorermsmith: Since at least 2005 Toyota Tacoma 4x4's do NOT have a neutral position for the transfer case. I used a DS disconnect.
Moisheh - wbrowningExplorerThanks for the replys guess I will look for a different rig
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
