Sjm9911's avatar
Sjm9911
Anyone use a water meter?
Ok, so recomend to me a garden hose style water meter. My TT does not have a gravity fill or overflow and i can not tell how much water is in the freash water tank. If you fill it up too much it can pressurize, wich is bad. Normally not a problem but when i was sanitizing it i forgot to swap over the valve, so i had no idea how nuch water i had in the tank. Then i forgot to switch the other valve over to shut down the siphon hose because i didnt see it. The controlls and pump are under the couch inside and its a pita to see or feel to open and close the right levers. They should make it easier! Lol. Or i should mark them one day.........
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
