- SHREDExplorerThanks!!
- macjomExplorerCan't go wrong with 3m command strips. They are very tough.
- trb46ExplorerWhen using Command Strips, prep the wall per the directions, alcohol wipe and all. If it say press and hold for one minute, do it a bit longer. As Old-Biscuit said above, prep is the key.
- Edd505ExplorerCommand strip many sizes available at Walmart.
- rk911Explorer
JimR 1 wrote:
I used Command Strips for 3 pictures and so far they work, there is a general purpose Command Hook also. When it comes time to remove ? will see.
Go to the web site Command
JimR
been using 3M Command Strips ih the MH and at home since they were first introduced. They are as advertised. They used to make a few of the Command products designed for outdoor use. They work just as well indoors but hold a bit better for larger objects. - IAMICHABODExplorer IIX2 on what Old-Biscuit said, my experience also going on 10 years and no failures.
- Old-BiscuitExplorer IIICommand Strips hands down!
Hung lots of different size pictures..small to large/light to heavy in our 5th wheel in 2007.
Traveled all over the USA...and not only are they still hanging. NONE ever fell off the wall
Clean the wall---prep is the key - Community AlumniI used Command Strips for 3 pictures and so far they work, there is a general purpose Command Hook also. When it comes time to remove ? will see.
JimR
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
